midicontrol - what works?
  • Guest
    by Guest » Sun Nov 06, 2005 4:30 am
    Does anybody have advice on what type of midi controller works best ?? I know there's alot out there - I'm looking for a unit that's small and simple to use for live performances.
    help
    siren
  • stuart
    by stuart » Mon Nov 07, 2005 9:43 pm
    can't say what works best per se but I have a UC33 and am happy with it.
  • shiva01
    UC 33 works fine....
    by shiva01 » Thu Feb 23, 2006 4:00 pm
    ...same here...
    sometimes using kaosspads midi....works well too!
    chris
    gmint
    by gmint » Thu Feb 23, 2006 8:07 pm
    I like the BCR 2000. Lots of knobs, lots of buttons, good indicator lights...
    DJ G Mint
    cal6n
    by cal6n » Thu Feb 23, 2006 8:27 pm
    Chalk up another happy UC33E user
  • Akira
    by Akira » Thu Mar 02, 2006 3:26 am
    My faves
    Currently using an Edirol PCR-30, got used to it!
    Best one IMO has to be the BCR2000
    And I tested the UC-33 with good results, a nice all-round controller (I don't like its buttons though)
  • nwmarco
    Korg Kontrol/microKontrol?
    by nwmarco » Fri Jun 02, 2006 8:37 am
    Anyone with experience using a Korg Kontrol or microKontrol?
    16 pads for triggering media, 8 sliders, and more!
    I think it may be time to move up past the trusty Oxygen 8.
    Cheers,
    Marco
    by franz » Fri Jun 02, 2006 11:35 am
    i'm usin' Korg microkontrol, and it is quite nice.....
    i just don't need the piano keyboard.....
  • mannikin
    Re: Korg Kontrol/microKontrol?
    by mannikin » Fri Jun 02, 2006 8:47 pm
    Happy with my microKontrol. Perfect lil controller and does the job nicely.
    J.
    Cheers,
    Marco
    S Y N F O N Y<> S T U D I O S
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
    http://www.synfony.com
  • nbd
    by nbd » Sat Jun 03, 2006 11:08 am
    I used midiman Oxygen. Was nice for triggering clips. However, has only 8 sliders for additional use.
    Now I have a alesis photonx25. It has keys, 10 (!) endless (!) sliders/wheels and it also has 10 triggers. looks quite good.
  • aux_armes
    by aux_armes » Sat Jul 15, 2006 12:00 am
    I'm using a BCR2000 and a m-audio triggerfinger...I'm very pleased with both.
    M
    fati.V
    by fati.V » Sat Jul 15, 2006 8:05 am
    I'm using a cheap one: "evolution UC16" works fine... :wink:
    ri
    Re: midicontrol - what works?
    by ri » Sun Sep 30, 2007 4:21 am
    I'm using a Novation 25sl that I also use for ableton Live. It appears to work very well... much easier to program than my old Korg Kontrol 49.
    quote="Anonymous"]Does anybody have advice on what type of midi controller works best ?? I know there's alot out there - I'm looking for a unit that's small and simple to use for live performances.
    help
    siren[/quote]
  • Lupin
    by Lupin » Sun Sep 30, 2007 6:06 pm
    M
    yeah this config. is very comfy!
  • mowgli_uk
    by mowgli_uk » Tue Oct 02, 2007 3:38 pm
    M
    So that's three of us then!
    About which controller works best, its more a case of what you want to do and then find the controller that is suited for that. I suggest that you don't get any at the moment and play about with md8, you'll soon figure out which parameters you want to have direct control over.
Users browsing this forum: No registered users and 52 guests
