What are freeframe plugins??
  • mannikin
    by mannikin » Tue Nov 08, 2005 4:13 am
    Forgive me if this is a very obvious question! I keep hearing that so-and-so software supports these plugins. What are they, and what is their advantage? Appreciate the info.
    J.
    S Y N F O N Y<> S T U D I O S
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
    http://www.synfony.com
    yves@garagecube
    Re: What are freeframe plugins??
    by yves@garagecube » Tue Nov 08, 2005 11:02 am
    Freeframe is a protocole which defines a standard for the creation of video plug-ins that can be used in imaging/video applications. It is like the Photoshop plug-ins but for video. Also the protocole is not proprietary. Anybody can write Freeframe plug-ins and any applications can use them (as long as they write the necessary code).
    There are many Freeframe plug-ins, commercial or free. Freeframes are not very developped on the Mac platform. However it mays change now that several VJ applications support or will support them.
    Yves.
    VJ-A2D
    by VJ-A2D » Tue Nov 08, 2005 3:41 pm
    Plus2 Collectiv
  • jm302
    by jm302 » Wed Nov 23, 2005 10:49 am
    Greetings,
    Looks like Pete Warden is at it again:
    http://www.vjforums.com/showthread.php? ... adid=13873
    Cheers,
    Justin
    http://www.302acid.com
  • mannikin
    by mannikin » Wed Jan 04, 2006 12:37 am
    Awesome. Thank you for posting this.
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
    yves@garagecube
    by yves@garagecube » Wed Jan 04, 2006 11:15 am
    Do not judge the performances of CI in Modul8 by extrapolating Pete Warden CI bridge's performances.
    While it is a nice project, the main problem is that it forces CI to work in software mode due to the FF CPU oriented nature. In Modul8 CI filters are applied directly in VRam using the GPU (when supported by the graphic card), so it is a lot faster.
    Unfortunately it is nearly impossible to integrate CI inside FF without a big lost of performance. It is a shame because it would have saved me quiet a bit of work ;-)
