BACF MODULE disepeared!!!
    thease
    by thease » Fri Nov 11, 2005 5:59 pm
    was looking into the library, and the BACF module has disepeared...:?
    would somebody be so kind to put it back to the Public library?.... :P
    thanks,
    Answer in english or French : as you prefer!
    Répond en français ou en anglais : comme tu préfère
    VJ-A2D
    by VJ-A2D » Fri Nov 11, 2005 7:29 pm
    it is part of the modul8 installation... it is by default in your library folder when you install m8 !
    Plus2 Collectiv
    thease
    by thease » Sat Nov 12, 2005 5:19 pm
    it is not in it!
    Strange, it must be because I had to reinstal it on a new hard disk...
    i'll check with the support..
    tnanks for your help
    thease
    by thease » Sat Nov 12, 2005 5:37 pm
    ok...I forgot had a Backup of the moduls...and thanks to your answer I found it in it... :oops:
