best place to trigger clips
    vjfj
    by vjfj » Wed Nov 16, 2005 10:10 am
    hi - is it better to store and play the clips on an external (7200rpm) firewire drive or directly from the local HD?
    -fj
    VJ-A2D
    by VJ-A2D » Wed Nov 16, 2005 12:17 pm
    It depends what you have as internal harddrive and computer. If you are using a PB firewire is the best option... trying to mix the contents half on your PB and half on the Firewire.
    If you have sata for example in a G5 :) forget about the firewire
    Plus2 Collectiv
    vjfj
    by vjfj » Wed Nov 16, 2005 12:51 pm
    i have a G5 serial ATA. and so far (other than my "other" problem) works fine...
    thx
    f
  • stuart
    by stuart » Thu Nov 17, 2005 11:38 pm
    I did a test with my G5 running the clips off of the internal VS running them off of a 7200rpm external firewire drive. The performance was very similar.
