ext. firewirecam and trace fx
  • vandeloow
    by vandeloow » Tue Dec 06, 2005 12:36 am
    hi,
    i really love the trace effect. :shock:
    but when i use the livecam, the trace effect is gone. it doesn't work. is this normal?
    thanxs!
    .martin
  • studioc
    by studioc » Tue Dec 06, 2005 3:38 am
    I have found that when I reduce the opacity of underlying layers the trace effect is amplified. I would prefer if the trace effect worked at full effect over full opacity layers, but not so far for me. I have not experimented with the firewire camera in and trace, though.
    The Revolution must be televised!
  • jm302
    by jm302 » Tue Dec 06, 2005 5:37 am
    I kinda figured that by the nature of the trace effect it's necessary to keep a low layer opacity, especially when using multiple layers.
    j.
    http://www.302acid.com
    vjfj
    by vjfj » Tue Dec 06, 2005 2:49 pm
    martin i used the trace effect during a live set on the livecam. i had chanels a & b stacked with multiple (all) layers, camera on ch A, and was fading between layers in B while the camera picture was slowly turning 360 horizontally in 100% opacity with the trace effect on, which resulted in the edges of the frame that was turning leaving a nice trail. looked cool and worked perfect.
  • vandeloow
    by vandeloow » Tue Dec 06, 2005 3:29 pm
    hi,
    thanks for the information. so the trace effect has no effect on the movie content, right?
    .martin
    vjfj
    by vjfj » Tue Dec 06, 2005 4:06 pm
    hi,
    .martin
    well it's a "global" effect (in the master section) so whenever it's on, it affects all videos. i can't remember exactly if it afffected the edges only of a clip or the movement WITHIN the clips also. you'd have to try it out. i was using slow action clips so i didn't notice it (within) but i also noticed when i shrunk the clips and used "patch" to make them round had them orbitting around the screen. a nice effect for simulating comets btw :)
    yves@garagecube
    by yves@garagecube » Tue Dec 06, 2005 8:17 pm
    Yes, the trace effect always affects the complete composition. It is not a layer effect. It is achieved at the last compositing stage (when all the layers are rendered).
    by boris » Wed Dec 07, 2005 2:43 am
    You can use trace like motion blur, use one layer in your composition and put the transparency of your layer to 50%
    Jesper Fryd
    by Jesper Fryd » Wed Dec 07, 2005 7:44 pm
    don't forget to download the module that automates trail-up/alpha-down.
    i use it all the time instead of just trail.
