...truble with (x,y) field..
    zava
    by zava » Sun Dec 11, 2005 10:05 pm
    hi
    i have a small truble with (x,y) field on module.-..
    i can capture the x value from code.,,.
    if msg='pippo':
    v = param['x']
    and the debug say x is wrong,.,.,.
    i print the output and its it is a dictionary....
    printed 2 times,.,.,.
    why,.,.,.
    its happen just with (x,y) area control
    :::: zava ::::
    :::: Vjcentral.it ::::
    :::: vimeo ::::
    yves@garagecube
    by yves@garagecube » Sun Dec 11, 2005 11:26 pm
    x and y do not arrive necessary in the same message. So you have to verify that the x and y keys are present before reading them:
    For instance:
    Code: Select all
    if 'x' in param: # Does 'x' exist in the dictionary ? print param['x'] elif 'y' in param: # Does 'y' exist in the dictionary ? print param['y']
    zava
    by zava » Wed Dec 14, 2005 12:00 am
    perfect,..,.,
    tx,.,..,
    is online
    :::: zava ::::
    :::: vimeo ::::
