"save project" saves hardly anything than the medi
    p8guitar
    by p8guitar » Thu Dec 29, 2005 1:43 am
    When I save a project, none of the layer settings or effect settings are saved. The only thing that remains from my work is the information which media were loaded into the media panel.
    I hope this behaviour is not by design but an user error, because this is the reason why I don't use Livid's Union no more - I have to start from scratch every time I open the project that I'm working on.
    Please tell me I'm doing something wrong... :(
    VJ-A2D
    by VJ-A2D » Thu Dec 29, 2005 10:48 am
    Do you have your settings in the preferences set as "Save to Document" or something?
    Plus2 Collectiv
    p8guitar
    by p8guitar » Thu Dec 29, 2005 11:34 am
    Unfortunately I cannot find preferences that deal with saving. I only see "media", "video capture" and "key/midi mapping" in the preferences.
    (Modul8 2.5.4, Mac OS 10.4.9, iMac 2.33GHz Intel Core 2 duo / 2GB RAM; MIDI: RME fireface 800, Novation Remote ZSL, Korg microKontrol, Faderfox LV2 and LX2. )
    yves@garagecube
    by yves@garagecube » Thu Dec 29, 2005 8:49 pm
    Did you call "Save Map As Defaults" from the "Mapping" menu ? You have to call this function to save your mapping preferences.
    Check the page 33 (also page 36) of the documentation "Midi and Keyboard" mapping for more informations.
    Also: Mapping preferences are not saved to the documents unless you set in the preferences under "Key/Midi Mapping", "Use Document Configuration".
    p8guitar
    by p8guitar » Thu Dec 29, 2005 9:22 pm
    yves@garagecube wrote:Did you call "Save Map As Defaults" from the "Mapping" menu ? You have to call this function to save your mapping preferences.
    You misunderstood me,Yves. My problem is that when I reopen the project, there is only one layer, and the project is in default state. All layers, effect settings, transparency settings and so on are gone. (But the media panel is still filled with the correct media.)
    I cannot think of a reason why it should be helpful to set all settings to default when a project is saved? Then why save at all? :?
    Re: "save project" saves hardly anything than the
    by boris » Fri Dec 30, 2005 8:52 am
    What exactly is not saved on your project ?
    What version of modul8 do you use ?
    Thanks.
    p8guitar wrote:When I save a project, none of the layer settings or effect settings are saved. The only thing that remains from my work is the information which media were loaded into the media panel.
    p8guitar
    by p8guitar » Sat Dec 31, 2005 1:57 am
    I think I have found the problem. The project that could not be saved properly had a media loaded in the media panel that wasn't accepted or detected correctly. It was a quicktime "movie" without picture, only sound in AAC format (see my other post...).
    This movie confused everything I guess. I assume modul8 continuously tried but couldn't load it, this prevented the project from being loaded correctly.
    by boris » Sat Dec 31, 2005 2:05 am
    Sorry I missed some messages...
    Yes a quicktime without picture can cause problems.
    But what version of modul8 do you use (is Important) ?
    Thanks.
    p8guitar
    by p8guitar » Sat Dec 31, 2005 1:07 pm
    I use Version 2.0.2
    VJ-A2D
    by VJ-A2D » Sun Jan 01, 2006 4:04 pm
    boris wrote:But what version of modul8 do you use (is Important) ?
    It's written in his signature ! ;)
    Plus2 Collectiv
    by boris » Sun Jan 01, 2006 7:40 pm
    Ooops :oops:
    Ok, I will test this problem...
