resolution of flash animations
  • breakit
    by breakit » Sat Jan 07, 2006 9:26 pm
    i´ve created some flash animations with moving objects for using in m8. the problem is that the flow stops at several times. i tried a resolution of 720x576 in these flash projects. may be it´s to much. so what´s your advice to an acceptable resolution of flash projects which will be used in m8? and are there differences in handling flash clips between swf and mov format? and what ist the best frame rate of flash clips?
    yves@garagecube
    Re: resolution of flash animations
    by yves@garagecube » Sun Jan 08, 2006 2:24 pm
    Flash is slow, especially at high res. My advice to get the best performance is to convert them to a video.
    Yves.
    xrayconcept
    by xrayconcept » Thu Feb 16, 2006 2:51 pm
    Is the use of several flash files in a project a reason why a modul8 project size could be bigger than usual?
    I have one project with many flash files wich is 94 Mbytes instead of the usual 1 or 2 MB :shock:
    Thx
    Pixray > xray concept
    Xray C Blog
