vjfj wrote:i did exactly that at a recent gig. i ran a live signal from a remote source into the s-vhs input, monitored the channel i had assigned the camera to until specific action occurred. then i would fade it in. had it set to the top most layer so it would block out all the lower layers and then, when as it swung around to fill the whole screen i wold switch the layer(s) underneath to play different clips. looked cool
If you hook up your camera to the fire wire video capture and tell your camera to play the line-in s-video, RCA works too if your have the conversion, then create a new layer to play the video capture and add a little X, Y, and/or Z spin on the layer and just like that you have a new fun effect. Check it out, it's fun!!
moonbase wrote:If you hook up your camera to the fire wire video capture and tell your camera to play the line-in s-video, RCA works too if your have the conversion, then create a new layer to play the video capture and add a little X, Y, and/or Z spin on the layer and just like that you have a new fun effect. Check it out, it's fun!!
Hi Videofile I'm missing something here! Help an old man out.... routing what where?
vjfj wrote:not totally sure i know what you mean by fractals - but using the transformer i was able to throw the rotating screen / live camera feed into a cool cube matrix, generate particles and the like quite easily - the most important consideration having had more to do with artisitic taste than possibilities
however with M8 2.5 on the horizon, GPU driven and freeframe fx i can't wait to see what will be possible.
cheers in AZ! i once had the fortune to live in sedona for 5 years!
