multiple outputs possible?
    vjfj
    by vjfj » Wed Feb 01, 2006 10:40 pm
    hi if i have a second video card, is it possible to assign M8 to output to that while i output a different signal to my other card? all that i see is "full window" mode. is there a setting where i can have more control?
    hope that is clear enough.
    thx
    -fj
  • ichmirmich
    I want to know it, too!
    by ichmirmich » Thu Feb 02, 2006 1:48 pm
    Oh yes...is this possible?
    or how is it possible to send 2 signals from my powerbook to 2 beamers?
    vjfj
    by vjfj » Thu Feb 02, 2006 2:00 pm
    send two separate signals (output from M8 to one card and output from another pgm)
    in other words, if i have 2 cards 'A' & 'B' select videocard 'A' as output of M8 and video output 'B' for another application.
    of course that leads to the question is it possible to split M8 ooutput into 2 and send each one to a separate video card output/beamer
    lego_man
    by lego_man » Thu Feb 02, 2006 2:04 pm
    it will be possible in with Modul8 2.5 :D
    vjfj
    by vjfj » Thu Feb 02, 2006 2:09 pm
    my birthday is in 2 weeks...
    any chance??? :roll:
    by boris » Fri Feb 10, 2006 4:43 am
    In the next version 2.5 it will be possible to use multi output, but only with pci-express video card. (last G5 tower).
    vjfj
    by vjfj » Fri Feb 10, 2006 9:40 am
    i assume then, you mean if i have 2 video cards installed i can run one signal from one card using extended desktop mode, and a second, different signal out of M8 from the other video card.by different signal i mean not the same mixed output but a different mix altogether. is that the case? or will it function like a "mirror" mode, simply allowing me to send two signals of the same mix?
    yves@garagecube
    by yves@garagecube » Fri Feb 10, 2006 6:53 pm
    You will be able to send any area (even overlapping rectangles of different size) of the whole composition to any of the VGA output. It is very flexible and performances are pretty good.
    With two cards, you can have four different outputs (one used for the UI).
    Yves.
    vjfj
    by vjfj » Fri Feb 10, 2006 7:11 pm
    very very cool!!!!
  • bratch
    by bratch » Fri Feb 10, 2006 7:19 pm
    which card do you suggest for the 4 output configuration?
    :P
    by boris » Sat Feb 11, 2006 3:48 pm
    It works well with a simple pci-express NVIDIA GeForce 6600.
    You can use 4 VGA output.
    But with these card, if you want to use video, it seems you have only two vidéo composite output (one per card) and also two VGA.
  • bratch
    by bratch » Sat Feb 11, 2006 7:19 pm
    do you need to buy an Nvidia card for MAC or does any Nvidia 6600 fits a Mac (sorry ,i know it's not the topic for this forum, but it would help...) ? :D
  • eskatonia
    by eskatonia » Wed Feb 15, 2006 2:19 pm
    I'm very interested in multi output as well...
    is it not possible to get three video outputs with two cards?
    using DVI-S-Video converters? or is it really not possible...
    I'm looking to spec out a G5 tower with five outputs for a large installation.... want to go video rather than VGA if possible.
    hmm just checked it out...
    each Geforce 6600 has two DVI outputs. What stops you installing 2 6600 cards, connecting one as VGA for your interface window then buying three DVI-S-Video converters.
    Does the Mac OS X software not work with this? otherwise it's scan converters I guess...
  • bratch
    by bratch » Thu Feb 16, 2006 2:34 pm
    yves@garagecube wrote:You will be able to send any area (even overlapping rectangles of different size) of the whole composition to any of the VGA output. It is very flexible and performances are pretty good.
    Yves.
    So if you have 2 or 3 beamers with an edge blending, you can overlap the borders of each screen easily to make a panoramic screen, keeping a great resolution, am i right?
    yves@garagecube
    by yves@garagecube » Thu Feb 16, 2006 11:00 pm
    Eskatonia: From our test it was not possible to have two video outputs on the same Geforce 6600. You can have 1 VGA + 1 Video or 2 VGAs, but not 2 videos. Don't know if it is a hardware limitation.
    Bratch: Yes, you are right.
Users browsing this forum: No registered users and 65 guests
