evolution mk 425c -- midi mapping is deleted
  • leuchtstoff
    by leuchtstoff » Sun Feb 19, 2006 5:26 pm
    just bought an evolution mk 425c midi keyboard.
    everything is fine. just got a problem. when i name the keys which fuction they should have- these settings are deleted when i shut down modul 8 and start it again.
    and does anyone know how to give the keys a doube-usage. so you can combine for example knob 1 + wheel 1 for another use than knob 2 + wheel 1..?
    sorry for my bad english. got a big hangover, but i need to know this now :D
    cheers
    new kid in town
    by sigmasix » Sun Feb 19, 2006 7:03 pm
    to keep your settings in memory, just choose "save map as default" in the mapping menu
  • leuchtstoff
    by leuchtstoff » Sun Feb 19, 2006 9:00 pm
    :oops:
    ohh, jipp.
    but the more important question is about using keys in combination .. anyone knows something about?
    new kid in town
  • jm302
    Re: evolution mk 425c -- midi mapping is deleted
    by jm302 » Mon Feb 20, 2006 12:43 am
    leuchtstoff wrote:and does anyone know how to give the keys a doube-usage. so you can combine for example knob 1 + wheel 1 for another use than knob 2 + wheel 1..?
    Greetings,
    You should be able to use MIDIPipe http://homepage.mac.com/nicowald/SubtleSoft/ to do that. If that doesn't do what you need, give Plogue Bidule a try http://www.plogue.com/ Good luck!
    Cheers,
    Justin
    http://www.302acid.com
Users browsing this forum: No registered users and 52 guests
