Trace + master Add color bug
    VJ_JeSs
    by VJ_JeSs » Wed Mar 01, 2006 6:07 pm
    Just a small bug I came across a while back. Just thought I'd adress it before the next release :)
    When using the trace effect. If you push any of the master add color sliders the opacity seems to fall down (as soon as you add a tiny bit of "add color").
    Using the specific "add color" of the layer, it does not happen.
    Could that be corrected in the next release ?
    Thx
Users browsing this forum: No registered users and 86 guests
