Clavier ESI
    Sam
    Clavier ESI
    by Sam » Thu Mar 02, 2006 10:41 am
    Que pensez vous de ce Clavier ?
    25-key USB MIDI controller
    KeyControl 25 is a new versatile MIDI controller for computer music and live performance. It can be used as soon as it is connected to a sound source or even to a computer. You can connect KeyControl 25 to your Macintosh or PC via a simple USB connection. No additional power supply is required. KeyControl 25 offers numerous controllers: it has 3 wheels, 8 knobs, 8 encoders and 20 buttons. The 8 knobs and 8 encoders can even be assigned twice, just switch between the two banks by pushing a button. Of course all controllers work in real time. In addition, KeyControl 25 is equipped with a polarity changeable sustain pedal jack and you can change the sensitivity of the velocity curve.
    Plug-n-play in Perfection!
    No need to install driver in Mac OS X and Windows XP environment --it is automatically recognized by plugging in the USB cable. Problems of failure or collisions of driver install can not happen.
    Specifications.
    - 25 note full size semi weighted velocity-sensitive keyboard
    - Rubberized pitch bend, modulation and data wheels
    - 16 function buttons and 4 data buttons
    - 8 data knobs and 8 encoders for easier data variation
    - USB MIDI In/Out and 1 MIDI-Out Port
    - 3-digit LED display
    - Sustain Pedal connector
    - External DC Power adapter connector
    - Compatible with Windows XP/2003, Mac OS X (later then 10.2)
    pensez-vous que ce clavier peut etre utilisé avec Module 8 ? :wink:
