Now I'm having a problem with the MIDI mapping. Seems to me like modul8 is stuck in OMNI mode?
My setup consists of an Edirol PCR-30 interfacing my iBook G3 with a Korg Electribe EA-1. I have completed mapping my computer keyboard and MIDI to my liking. The problem lies with the Electribe. It's sending MIDI data on two channels, and modul8 takes all that is sent to it from these two channels. I use one of the parts for audio and the other one for video, so it's messign it all up. I can't filter that within the machine or make one of the parts not send any MIDI.
Would there be any way to be able to select which MIDI channel the program will react to? Is there something I'm missing that makes this possible already? I was thinking that if there isn't, modul8 recognizing the channel where the command is coming from and assigning it *exclusively* to that channel, would be good. So while editing the MIDI map, if I press a note in my keyboard on channel 1, modul8 would program itself to take that note on channel 1 as the input, and not the same note on any other channel.
Would be great to have help on this, specially since I would love to use modul8 in an A/V venue I have the 28th and this feature is of extreme importance!
Cheers,
