pause when changing movie in layer...
  • joshuapearson
    by joshuapearson » Sat Mar 11, 2006 5:38 am
    i'm trying to smoothly crossfade between group A and B, and swap the movie out of A while i'm on B, but the movie which is playing in the output window always seems to pause momentarily when i click on a new movie in the media panel...
    i admit i'm on a slow machine... a 3 year old 1.25 ghz G4 laptop... but i'm not in "full screen" mode...
    i'm using short photo-jpeg 640x480 movies, no sound... will i always get this little pause?
  • jm302
    Re: pause when changing movie in layer...
    by jm302 » Sat Mar 11, 2006 9:12 am
    Greetings,
    I'm using the same box you are... unfortunately, 640x480 clips are a bit much for it. Try scaling down a bit(if you can live with the lower rez) or maxing out your RAM and having the clips you're trying to load set to fully decompress in the memory. Good luck!
    Cheers,
    Justin
    http://www.302acid.com
