Advanced Text Module possible?
  • deckard97
    by deckard97 » Tue Mar 21, 2006 3:27 am
    Question for GarageCube team:
    I want to know if, with the help of a module I could try to write, it would be possible to do this:
    A text module that would read text from a file, line by line.
    Say I have a .txt file, I choose it through the module and I have "next" and "previous" buttons in the module (MIDI configurable, of course) and each time I would press "next" it would load the next line of text. and display it in the same "text container" I created.
    So I could start from the existing Text module and would only need a way to "feed" text to it, from a file.
    The application for this is to supply subtitles and be able to position them anywhere on the screen and rotate/scale them.
    Thanks for the help.
  • bratch
    by bratch » Tue Mar 21, 2006 9:30 am
    well if you make it, make sure to get us informed; this can be a very usefull module ! :P
    yves@garagecube
    by yves@garagecube » Tue Mar 21, 2006 10:28 am
    Yes this is possible and not too difficult to do. I don't have time to write myself now (with the V2.5) but I can help you.
    1) you should use Python functions to read the file as a string and split it by lines into an array.
    2) Then iterate through the array using the Next/Previous button
    3) Send the string to the corresponding Modul8 keyword.
    Let me know if you need help.
    Yves.
  • moonbase
    by moonbase » Tue Mar 21, 2006 2:57 pm
    That is just a great idea!!
    I've been avoiding thinking about learning Python because there just isn't enough time in the day, now that may have to change.
    Keep us informed please deckard97. There are loads of times when this would have been a great tool to have.
    There is little I can practically help with at the moment except idea bouncing.
    I guess I'm going to have to invent time travel just so's I can learn Python - damn.
  • bright!
    by bright! » Tue Mar 24, 2009 1:08 am
    even though this thread is very old ... did anybody acomplish to write something like that?
    i would love to have something like that.
  • deckard97
    by deckard97 » Tue Mar 24, 2009 2:47 am
    Nope.
