masks as screens
  • JasonTschantre
    masks as screens
    by JasonTschantre » Fri Sep 23, 2011 6:40 pm
    I have a simple question:
    Is it possible to create a mask in MM, and then use that mask as a screen unto itself? (rather than simply "cutting-out" that shape from a quad or triangle?
    The whole app would seem a lot cooler if I could figure out how to do that.
    Perhaps I would understand masks a little better if someone could give me a brief rundown of what the options "over pre-multiplied" "over" "add" and "ignore alpha" are best suited for.
    pele2010
    Re: masks as screens
    by pele2010 » Tue Jan 03, 2012 10:05 pm
    it´s posible, but it doesn´t make a "Hole" into your projection.
    So you can mask something, no light will come through.
    But you can´t fill it with another content.
    This is on the Wish List for the next Version of MM .
    see:
    viewtopic.php?f=29&t=7931
    I hope i explained it properly.
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
