No longer showing frames rendered?
  • martyw79
    by martyw79 » Mon Sep 26, 2011 5:22 pm
    When I 'Render Logical Record' the number of frames rendered no longer show on the output screen? Seems to have stopped appearing since updating to Modul8 2.6.4?
    It was pretty handy when it showed how much was still to render on a recording.
    The recording works fine but you can't see how much more needs to render.
    Marty
  • martyw79
    Re: No longer showing frames rendered?
    by martyw79 » Sun Oct 16, 2011 7:58 am
    can I assume it's only me who's experiencing this?
    by sigmasix » Sun Oct 16, 2011 10:00 am
    you're actually right, there's no text on it… I was not aware of that. I will check if it's a "normal" behaviour. In the meantime, you can always see the progress in the slidebar right on top of the master record button.
  • martyw79
    by martyw79 » Sun Oct 16, 2011 10:59 am
    Thanks for confirming. It's no biggie but was convenient when I left my laptop to render on the other side of the room.
    Will use the progress bar as a reference from now on.
