TouchOSC Template without Osculator
  • wavilox
    by wavilox » Wed Oct 19, 2011 3:59 pm
    Hi!
    Im new to this forum and i want share my TouchOSC Layout for modul8. Works with OSC Global module.
    DOWNLOAD---- http://www.wavilox.com/2011/08/touchosc ... odul8.html
    Re: TouchOSC Template without Osculator
    by ilan » Thu Oct 20, 2011 2:17 pm
    Cool. I will test it out. Thank you for sharing it.
    by ilan » Thu Oct 20, 2011 3:07 pm
    Nice ergonomics.
    Is this meant to work with 'feedback' as well? When I enable it there is a lot of strange things going on with the interface.
    For example when using the 'LIVE' section and changing media, when I press on '4' then number '3' gets highlighted. Then when I press on '5', '4' gets highlighted.
    In the 'LAYER ADJUST' section the 'reset' buttons do not function.
    I can report back an more when I have more time.
    birdiedaboy
    by birdiedaboy » Thu Oct 20, 2011 10:24 pm
    I have downloaded it and played for about an hour and it has work great! Its really nice for launching clips and adjusting layers and I really like the whole way its setup it feels so good when playing it! but I think you should put some fx controls in there would be really nice.
    The only thing I saw not working was the feedback from M8 to the iPad if I clicked something or use a slider the change wouldn't apear in the iPad, I know having this controls is suppose to help you stay out of clicking the computer but sometimes you just do and then grab the ipad again and everything starts kind of bumping, i dont know if there is and extra message that has to be send back to the ipad.
    You have done a nice job with this man, congrats and thanks for sharing,
    Repeat after me: I am free
  • wavilox
    by wavilox » Fri Oct 21, 2011 11:01 am
    Hi!
    This weekend will fix te reset function :oops: . I know the problem with Feedback, but I have not secured the solution :cry: . Any ideas?
    Thanks!!
    P.D: excuse my English!!!!
    by ilan » Fri Oct 21, 2011 11:36 am
    The feedback is a messy thing with TouchOSC. The solution to get it right is using OSCulator or writing a custom module similar to the Monomal module that would integrate your interface fully with Modul8. Neither is a very elegant 'out of the box' solution.
  • wavilox
    by wavilox » Wed Nov 09, 2011 3:12 pm
