Problems when Minimising
  • scaryxpuppy
    by scaryxpuppy » Fri Oct 21, 2011 7:02 pm
    Hi there.
    Am having an issue where I minimise MADMAPPER when running in show state to my external output......
    It will not allow me to RE-MAXIMIZE it...!!!
    I have to show VIEW DESKTOP and then close this, and then I can RE-MAXIMIZE??
    Any ideas?
    PHIL M
    Re: Problems when Minimising
    by franz » Sat Oct 22, 2011 12:48 pm
    interesting.
    We'll investigate on this.
    Meanwhile, don't minimize, but use the little arrow at the top of MM sidebar to hide both input and preview output views.
    alonsorama
    by alonsorama » Thu Nov 17, 2011 9:54 pm
    i notice the same problem only occurred
    when system references> dock> minimize into application icon its check
    also
    found that if you select more then 10 times the same area into quad input, the quad output start bouncing :s
  • moizez
    by moizez » Sat Nov 26, 2011 7:30 pm
    It happened the same to me, in the middle of a gig! It ocurred after I disconected the vga cable with madmapper on. Everytime I opened the application it went to minimize automatically and I could not maximize it again.. had to map with modul8 alone.
    by franz » Sat Nov 26, 2011 8:25 pm
    MadMapper will memorize the current setting of its main view (minimized, maximized, position...) on Quit.
    So basically if you quit minimized, the next relaunch will be minimized.
    We've changed this behavior in the next upcoming version.
