Wishes x 3
  • scaryxpuppy
    Wishes x 3
    by scaryxpuppy » Fri Oct 21, 2011 7:06 pm
    Hi there,
    A few possible requests.......
    1) - The possibility to have a SHORT CUT key to toggle through the CORNER PINS of the currently selected surface. I use a custom TouchOSC layout for mouse and cursor control etc etc and this would make it much easier to select matrix corners
    2) - a way of showing co-ordinates of the CORNER PINS, for precise line up
    3) - a way of disabling the DESKTOP/EDIT WINDOW preview screens when running in extended mode so as to free-up processing power!
    4) - loads more MADLAB plugins ! theyre awesome !
    Keep up the good work
    PHIL M
    Re: Wishes x 3
    by franz » Sat Oct 22, 2011 12:51 pm
    2- it's on our todo list. Should come in a future update. (but maybe not the very next one)
    3- use the little arrow on top of the MM sidebar. This will hide both the input and preview output views. And you'll gain a speed-up.
