New Soft Edge Blending Tutorial
  • B3Bear
    by B3Bear » Sat Oct 22, 2011 12:34 am
    Edge Blending with Modul8 Demystified:
    http://youtu.be/6Wt1GmOopVo
    Be sure to watch through flash because I update the annotations. This method doesn't work with all colors/media.
    I use a high res gradient mask file along with the Mask (Global) module to blend the edges. By adjusting the scale/ratio of the mask, I can change the width/shape of the blend and dial it in for the screen overlap. It's basically just two layers playing the same movie, each cropped through Crop Layer (udart) so they only show one "projectors" worth of movie and therefore when played in snyc you only get overlap on the edge, which you then blend out.
    The files are here:
    http://bearslooptasticspectacular.com/edgeblending/
    I used an easycap to go s-video from my DVR into SP>Video Input #1 and now I watch satellite tv on my 20 foot screen, in my 400 square foot studio apartment. :shock:
    Hope that helps! :mrgreen:
  • B3Bear
    Re: New Soft Edge Blending Tutorial
    by B3Bear » Mon Nov 14, 2011 2:00 pm
    So it turns out this actually works way better then I thought. The problem I was having with some videos was just a cropping issue caused by a different aspect ratio. I've posted an addendum to my tutorial...
    http://youtu.be/S0P7ypQXsuU
    Hope that helps! :D
