Thanks for the tips, I kept reading and everyone said they are only good for powerpoint presentations as you said, running live feed trough them will be with a lot of latency, and didn't even thought about all the cellphones that might mess up the thing! but its good to know now! but it will be so sweet if someday this works with live feed with no latency but for now lets stick with the cables! =)That system is more for screen sharing powerpoint presentations and would not be ideal for constant, low latency, video feeds.
Unless you spend tens of thousands of dollars on a broadcast wireless system you'll never be able to guarantee reliablity of wireless feed. Imagine a room with 500 people who have 500 cellphones which half probably have bluetooth and/or wifi on. You soon end up with mess of signals that will probably interrupt your feed.
Nothing can or will replace a physical cable running from A-B.
Users browsing this forum: No registered users and 67 guests
