Modul8 output to PureData
  • popesz
    by popesz » Sun Nov 06, 2011 6:08 pm
    does anyone know how I could add the modul8 output to PureData? Is it via syphon or any other trick is needed. And what is the object in PureData as video input?
    Thanks in advance:
    Popesz
  • bareimage
    Re: Modul8 output to PureData
    by bareimage » Thu Nov 10, 2011 8:21 pm
    Thanks in advance:
    Popesz
    It is not working yet. I would suggest working with Jitter instead of the PD/Gem. The support for syphon from Jitter is impressive. If you have a specific patch that you need to pipe your data to, then wait for the implementation. There is a preliminary work that have been done on this by Vade, but I do not think it is finished. Cheers, Igor.
