RAM
  • videofile
    RAM
    by videofile » Fri Apr 14, 2006 12:37 pm
    ok, well i just got some RAM and in my activity monitor i show that my real memory is only running around 440MB, which was the same that it was before when i had 512MB. Now i have 2G, yahoo, but shouldn't M8 be useing more of my real memory? (I have a G4 with a 1.6GHz processor)
    -VideoFile
  • jm302
    by jm302 » Sat Apr 15, 2006 12:00 am
    I would guess you'd need to set your media to fully decompress into RAM for it to take full advantage of the 2GB.
    Cheers,
    Justin
    http://www.302acid.com
  • videofile
    by videofile » Sat Apr 15, 2006 1:47 am
    jm302 wrote:I would guess you'd need to set your media to fully decompress into RAM for it to take full advantage of the 2GB.
    Cheers,
    Justin
    how would i do that? i don't see it in my preferences.
    do you mean 'uncompressed memory' in my Media Set window under the info tab?
  • bighairmusic
    by bighairmusic » Sun Apr 16, 2006 11:52 am
    I think you have to adjust the amount of RAM that Modul uses in the 'Medias' preferences tab. Both 'when opening a new project maximum preload memory size' and 'when imported a media is stored in memory its size is less than'.
