Storing IN & OUT and speed for each clip?
  • nbd
    by nbd » Mon Apr 17, 2006 2:34 pm
    Hi modul8er,
    is there a way to store In&Out-Points as well as speed as a setting for each clip in Modul8?
    As far as I work right now,
    the settings for in and out and speed are made for the layer, not for the clip. as I change the clip in the layer, the speed/in/out from the former clip will be applied to the current clip in that layer.
    I like to work the other way around: Store In&Out&speed for each clip and THEN apply that clip to a layer.
    Is this possible? How?
    Thank you,
    andreas
  • bighairmusic
    by bighairmusic » Tue Apr 18, 2006 11:52 am
    yes i have noticed that there are quite a few things i would like to do at the clip level (a bit like ableton live) that you can only do at a layer level. In and out points would be great. All controls being at the layer level for everything means that you have to prepare your clips before hand a lot more, and loading clips on the fly becomes a bit trickier as they always have to be in a layer which corresponds to the settings you'd like.
  • nbd
    by nbd » Sun Apr 23, 2006 3:09 pm
    So,
    is it possible? or not? Storing IN/OUT on Clip level?
  • moonbase
    by moonbase » Sun Apr 23, 2006 5:52 pm
    No, that's not possible.
  • Lupin
    by Lupin » Mon Aug 28, 2006 7:03 pm
    i think you can build a module that stores in/out points and media name (v.2.5)
    you can build a function that snapshots properties of each layer. then store it with module.setDefaults() 8-)
    i hope someone will write this module and share it.
    if i have time I'll write it or or we can build it as a collective work
