LEMUR APP FOR IPAD
  • lamepantallas
    LEMUR APP FOR IPAD
    by lamepantallas » Wed Dec 07, 2011 11:51 pm
    So finally the Lemur app is out, and was wondering if it is recommended to control modul8 and how much will it differ from Touch OSC. Any thoughts or insights?
    g.
    Here is Peter Kirn`s take> http://createdigitalmusic.com/2011/12/t ... nt-1240048
  • lamepantallas
    Re: LEMUR APP FOR IPAD
    by lamepantallas » Thu Dec 08, 2011 12:32 am
    Found this template... and looks pretty well put
    http://liine.net/en/community/user-library/view/2/
  • lamepantallas
    by lamepantallas » Sat Dec 17, 2011 10:53 pm
    I have created my first M8 template for Lemur for Ipad.
    http://www.flickr.com/photos/gabbo_vm/6 ... hotostream
    I customized this template as my main interface for M8, which includes within the midi mapping, LT´s Live Monitor which I use for my VJ setup. I got almost everything mapped correctly except the preview panel: GROUP INV, GROUP A GROUP B, OUT MIX, OUT.
    When midi mapping the preview elements, I encountered the problem of not having midi mapping options on layer, focus and position options within M8.
    Any ideas how this can be accomplished?
    If anybody wants the template I´d be happy to share it =)
    Cheers from Honduras!
    gabbo
    PopVJ-Visual Label
  • jonnyhazuki
    by jonnyhazuki » Mon Jan 02, 2012 4:14 am
    I would very much like the template!
    I bought Midi Touch but was dissatisfied with some of its limitations.
    I bought Lemur, but one thing I cannot figure out.. on any app... is how to assign a layer to a fader. I can only seem to assign one fader to whichever layer is selected.. so I have to select the layer first, and then I can fade it in/out. This makes the performance sloppy..
    Please help!
  • lamepantallas
    by lamepantallas » Mon Jan 09, 2012 2:29 pm
    Here is my template for M8:
    http://liine.net/en/community/user-library/view/162/
    Give me a chance to respond, maybe I can help you out with the midi map, although I am not an expert, but managed to do it.
    cheers,
    gabbo
  • bright!
    by bright! » Thu Aug 09, 2012 12:28 pm
    Just started playing around with the Lemur App but could not connect it to Modul8. How does it connect? How would i map the midi map for the ready made presets which i can find in the Lemur forums?
    Does anybody have a quick start in 3 sentences for that? Would really appreciate any help.
    Best
    Thomas
  • lamepantallas
    by lamepantallas » Sun Dec 23, 2012 8:36 pm
    Just updated my Lemur template for Modul8. Free feel to modify it and share =)
    http://liine.net/en/community/user-library/view/339/
    Youll need the following modules.
    1. BPM Router Master
    2. (AT) BPM Global
    3. LT Live Monitor 4.5
    4. Preview Window Mapper
    5. OSC Global (For midi mapping)
    gabbo
    @esegabbo @popversus
