which sound codec is supported for 5.1?
  • yukijung
    by yukijung » Sun Jan 08, 2012 3:56 pm
    Hello all,
    I am working on a surround 5.1 video project with module 8 in multi projection + a triple head.
    I prepare my videofile in aftereffect and render it in 75% photojpeg codec . Than with quicktime pro I put on my 6 surround files...
    So I did my tests on modul 8 it worked out only with acc audio codec-and not with others...
    Could you precise me which audio codecs are the best to run on module8 ? and at which rate should the audio file be 44.100 or 48.000?
    Thank you so much
    Yuki
