Shortcut for "Input" and "View Output"
    pele2010
    by pele2010 » Mon Jan 09, 2012 3:56 am
    hi there,
    is there a shortcut for "Input" and "View Output" and Dual View,
    i can find the one for orientation but cmd o is open and alt or cnrl won´t work.
    thnaxs
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    Re: Shortcut for "Input" and "View Output"
    by pele2010 » Mon Jan 09, 2012 4:18 am
    Hi ,
    forgot to write that i´m working with the RC 1.1 MM
    thnaxs
    Peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    by pele2010 » Thu Jan 12, 2012 7:22 pm
    i guess there is no shortcut ?
    But if so: How do you manage the Software with an external device ?
    If you can´t map the Layer or the Mix , then you need to work in Mix Mode
    And the Output is controlled by looking at the projections ?
    Is there any paradigma for this ?
    Thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
    by franz » Mon Jan 16, 2012 3:45 pm
    there's no shortcut for switching from input view to output preview.
    I don't understand your second question.
    pele2010
    by pele2010 » Tue Jan 17, 2012 2:20 am
    hi franz,
    thans for answering the question.
    The 2nd Question is?
    Why can´t i use a short cut for this interface feature ?
    As you know I´m not that experienced with the software. So maybe there is a reason
    why it should not be touched with the keyboard.
    I work since 1995 on Avid MC and it´s greate to switch inbetween views with a simple shortcut.
    So why am i asking this:
    If you are not projecting the output and you work on a laptop with on monitor
    the space gets small.
    Switching between output and layer or mix to prepare a session would be great.
    On the other hand:
    Every Element in the Software can be mapped, why layerview,output, not.
    To that the last Question refereed.
    Maybe there is a reason that i can´t see because i´m still blind.
    So be the light.
    thanxs
    pele2010
    sorry for my english (i´m not native)
    #eachfilm01
    #pele2010
    www.eachfilm.de
    by franz » Tue Jan 17, 2012 11:31 am
    "Why can´t i use a short cut for this interface feature ? "
    because there's no shortcut. We're likely to address this in the future, actually you're the first one asking.
    pele2010
    by pele2010 » Tue Jan 17, 2012 9:52 pm
    Hi Franz,
    thanxs for the answer.
    Great to hear this.
    I don´t know why but for me it feels good if i can switch views.
    (And there is a lot that feels very good: especially that the App never stops running!)
    It´s not that i´m thinking what could be introduced to the software that isn´t been mentioned.
    Maybe it has to do with the way the AVID MC works with "preview" and "record" timeline.
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
