Spacescanner and Resolume
  • arthurchance
    by arthurchance » Tue Jan 10, 2012 1:25 pm
    I'm trying to work out how to use the space scanner in Madmapper to work with Resolume as I've been using that instead of Modul8 for ages. I've seen and read the tutorial by 1024 on how space scanner works with Modul8 and i was wondering if there is a resource that will help me make a set up in resolume.
    any help would be awesome.
    many thanks
    Re: Spacescanner and Resolume
    by sigmasix » Tue Jan 10, 2012 2:54 pm
    the spacial scanner gives you an image file that is pixel correct of what your projector "sees". You can use this image to produce your medias and use these medias in any app you want.
