How to Expand the Boundaries in Modul8
    pele2010
    by pele2010 » Sun Jan 15, 2012 11:09 pm
    if you import a small file 200x200 with alpha (png,tif,) :
    I have the problem that after applying the blur from the pixel fx it cuts
    with the boundaries of the layer.
    This used to be a problem in AE in the beginning. Usually you would nest
    the layer in a comp and the boundaries disappeared.
    Back to MD8:
    there is no nesting in MD8, but is there a way to suppress this behavior.
    I found out that the Box Blur (M8) in the Filter Module works different. It blurs the
    layer without affecting the boundaries.
    But if you take the (CI or FF) Blur effects they affect the edges.
    Is there a way to work around this?
    Am i the only one with this problem?
    thanxs
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
