Cross fade when looping a layer
    ellenpan
    by ellenpan » Sun Jan 22, 2012 6:39 pm
    Hi, is there any way I can set cross-fade when looping a single layer?
    I mean cross-fade the end and the beginning, so that it won't have the annoying jumps.
    Thanks in advanced!
    Re: Cross fade when looping a layer
    by vanakaru » Mon Jan 23, 2012 11:28 am
    I make loops with video editing/effects apps before hand. I suggest you do the same. There are good explanations how to make a perfect loop.
    If somebody have not write a module to do the fading you want why don't you create it.
    With M8 you can use Slideshow module fade feature if you make 2 identical copies of your clip but with different name and set play from 0 to 1(or any other pair) and click on ”wait for movie”.
Users browsing this forum: No registered users and 73 guests
