What is optimal footage resolution to work with Dual head?
  • AlexImix
    by AlexImix » Tue Jan 24, 2012 3:30 pm
    I'm going to play a sequence of precomposed fotages 1024x768 from Modul 8 to MadMapper and output via DualHead with two beamers on elements of building. So each screen will be 1024x768.
    Is that right or I have to make footages of 2048x768 and set syphon out to this resolution?
    The way I think is that if I use 1024x768 footage to crop part of it in MM preview and send it to map an area within one of the screens that is 1024x768 the picture should be Ok.
    Am I right?
  • scaryxpuppy
    Re: What is optimal footage resolution to work with Dual hea
    by scaryxpuppy » Tue Jan 24, 2012 3:42 pm
    If it's the same footage on goth screens, simply send a 1024x768 image from Modul8 into MadMapper and create 2 separate quads, and map accordingly to each projector - MadMapper will see the DualHead as one large projection surface (2048x768) and you just have to drag/move/skew as necessary.
    Good luck
    Phil
  • AlexImix
    by AlexImix » Tue Jan 24, 2012 4:15 pm
    Thank you for your quick reply. Actually I'm going to make 15 qads of different shape and size on 1024x768 fotage that I composed in AE and map four of them within one screen and the rest 11 quads map within another screen. Cannot test it cuz i dont have two beamers available for tests.
  • scaryxpuppy
    by scaryxpuppy » Tue Jan 24, 2012 4:20 pm
    Do bear in mind that using 15 quads will probably mean each individual quad is very low-res
    It might be worth compositing them all onto a larger source file over SYPHON
    1920x1080 will give much better results
    Phil
  • AlexImix
    by AlexImix » Tue Jan 24, 2012 8:04 pm
    Yes, I do. Just hoping that 1024x768 resolution would be acceptable taking into account that the real surfaces i will map quads onto are relatevely small biggest is 4x4 m and the most of them are 1,20x0,9 m. I'm not shure how my laptop can deal with sequence of Full HD clips each 2 min long. Thank you for your help. All the best to you.
    alonsorama
    by alonsorama » Sun Mar 04, 2012 2:45 am
    how did they go???
    Post your conclusions videos images hardware set-up and finals thoughts
    it will be appreciate
    deepvisual
    by deepvisual » Sun Mar 04, 2012 12:49 pm
    now then chaps.
    its not the screen size that matters, its the distance the audience is away from it that counts.
