Layer color invert
    pele2010
    Layer color invert
    by pele2010 » Mon Jan 30, 2012 3:18 am
    if you ad the "sub" blending mode to a layer to fill it into a mask or shape
    the result is that the layer gets inverted.
    Is there a way to invert the layer back ?
    If you use the contrast inverse it works but it doesn´t look that nice.
    One way i found is to "invert output color" but this is a master control.
    The other way is to use "invert filter" .
    thanxs for the help
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
