Hi Folks,
Has anyone that is working with a lemur/modul8 OSC template managed to get the active layer feedback to work correctly?
Valparaiiso wrote:You have to set your Lemur the right way, sending osc on 8002 and listening on 8000.
It's a bit confusing in the beginning but quite simple to use.
Some OSC software seems not to use the same grammar, I have to investigate.
Users browsing this forum: No registered users and 58 guests
