Problem with syphon
  • rgbeat
    Problem with syphon
    by rgbeat » Thu Feb 02, 2012 10:00 pm
    I have a question because i am having a issue when i use syphon with MM, and maybe someone had the same problem.
    Most of the things i do is using openframeworks, processing and unity3d mixed with MM and when i am running an app in openframeworks and then open another lets say unity3d, MM change the syphon source and place the Testcard screen. Its that a bug on MM or its something i am doing wrong?
    Thanks :D
    david
    Re: Problem with syphon
    by david » Mon Feb 20, 2012 8:00 pm
    Hello rgbeat,
    this is a bug in MadMapper, this will be corrected in the next minor release. You could get a patched version of MM by contacting me (David) at support [at] garagecube [dot] com with your serial.
    Regards.
    David
