Blackmagic intensity pro problems
  • produktionshuset
    by produktionshuset » Fri Feb 03, 2012 5:23 pm
    Hello fellow modul8ers.
    As i saw BM cards was the way to go i acquired one of these, however i seem to have some trouble actually getting inputs from it.
    - the card shows up just fine in my camera source, and I've selected 720p / 50hz (pal). - but i don't get any input.
    - what i have been trying sofar is to rig my DVI port from my 5870 gfxcard into the input of the BM card via a dvi -> hdmi cable, and have selected the output to be 720p / 50hz in screen settings.
    - could there be anything i have overlooked? - I'm running the newest - non beta version of "Desktop Video" (9.1)
    -Kind regards
    Søren
    lotech
    Re: Blackmagic intensity pro problems
    by lotech » Fri Feb 03, 2012 9:05 pm
    I had issues with output of out Intensity using 9.0 and so rolled back to 8.5 which fixed the issue.
    There isn't too much reason to be running 9.0+ unless you're running a new card or need FCPx output.
