My Fade module NEED HELP!!!???
    shveddi
    by shveddi » Mon Feb 06, 2012 9:17 pm
    Good afternoon.
    Question for people to create modules for themselves.
    That's trying to create a module based on the taken in the library. Modules: (s6) LayerFade (Layer)
    And such a problem. I can not make the module work correctly.
    When I pressed the button Fade, to disappear or appear an alpha channel is one of 10 layers. But when I pressed the button. The channel becomes active but disappears or appears the previous layer.
    Help solve the problem, who understands this. My modules, works incorrectly. [FILE LINK REMOVED BY ADMIN! THIS IS NOT A MODULE]
    Best regards Sergey
    Re: My Fade module NEED HELP!!!???
    by sigmasix » Tue Feb 07, 2012 12:45 pm
    I didn't understand what was your problem.
    The link you provided doesn't download a module… I don't know what you are trying but please, respect the community!
    shveddi
    by shveddi » Tue Feb 07, 2012 1:08 pm
    I apologize if you create one that is not the case.
    I am Russian, I use the translator google. therefore can be expressed incorrectly.
    Here is the link to my module. would like to see all the layers switched on and off correctly. At this stage, the module enables or disables the previous layer.
    http://www.sendspace.com/file/v6ywrh
    Sincerely Sergei.
    by vanakaru » Tue Feb 07, 2012 1:50 pm
    It seems to be fading between layers RELATED to one another. Like the one you clicked previously and the one you click next. Try to get understanding of the mechanics - maybe there is no fault in it at all.
    by sigmasix » Tue Feb 07, 2012 8:49 pm
    Привет Сергей,
    I was actually clicking the advertising banner :oops: Мне очень жаль
    My russian stops here.
    I couldn't manage to have your module listed in my modules list?! What version of modul8 did you use to modify the module?
    shveddi
    by shveddi » Tue Feb 07, 2012 10:23 pm
    My version Module8 2.6.4
    I myself have created a module. On the basis of the module "(s6) LayerFade (Layer)".
    But I can not understand the code.
    Need help in writing correct code.
    It is necessary to run all 10 layers. regardless of the active layer.
    http://vk.com/album4265931_72944926?z=p ... 1_72944926
    I would really appreciate help. :roll:
