Keyboard or Midi control of Preset selection?
    lotech
    by lotech » Wed Feb 08, 2012 6:40 am
    Can we do this? Am I completely missing this?
    Re: Keyboard or Midi control of Preset selection?
    by franz » Wed Feb 08, 2012 9:01 pm
    midi should come in a future update - it is just not ready yet.
  • scaryxpuppy
    by scaryxpuppy » Sun Feb 19, 2012 8:13 pm
    Cool - In order of preference for PRESET CONTROL :
    Low - MIDI
    Middle - OSC
    High - KEYSTROKE
    Fingers crossed
    PHIL
    david
    by david » Mon Feb 20, 2012 8:16 pm
    Hi scaryxpuppy,
    if you want to preview what Midi control of MadMapper will probably look like.
    - quit MadMapper
    - open Terminal application
    - type
    Code: Select all
    defaults write com.garagecube.madmapper midirouterEnabled 1
    - restart MadMapper, you should now have an "Edit | Midi Mapping..." menu
    Regards.
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 8:19 pm
    Many thanks - and perfect timing for a show this evening..... (hmm... maybe i'll wait 'til the morning !)
    Thanks again though
    PHIL
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 8:29 pm
    (I assume this is a non-working layout?)
    ......any timescales on ver.1.2?
    Regards
    PHIL
    david
    by david » Mon Feb 20, 2012 8:36 pm
    What do you mean by non-working ??
    This is perfectly working ... I tested it using a Korg NanoKontrol.
    Perhaps some Target/Property will be added/removed, the way Midi messages are interpreted will be changed.
    But this version should be fully functioning... however we do not support it.
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 8:39 pm
    Hmm... Just can't seem to get OSCulator in, but will keep on fiddling !!!
    Great function to add - congrats to all
    PHIL
    david
    by david » Mon Feb 20, 2012 8:48 pm
    Just tested with OSCulator and it works
      1) open Edit | Midi Mapping...
      2) click the Add button in the lower left of the dialog
      3) choose a Target/Property
      4) click Learn
      5) send an OSC mapped to Midi command, MadMapper should update : Channel, Type, Note/Command
    you could also enter manually the Channel, Type, Note/Command in case of other Midi devices are sending commands continuously that renders the learn mode unusable.
    PS: Only ControlChange and Note could be used ... other Midi messages are ignored
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 8:55 pm
    Cool - many thanks - !!!
    PHIL
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 9:15 pm
    Brilliant - was just my problem with a fader sending out 0-127 for presets, and my fat fingers not being able to select manually !
    Works a treat though !
    PHIL
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 9:22 pm
    Is there a MIDI PROTOCOL page you have??
    I can get CC's to work on faders, but would love to be able to trigger from BUTTONS directly?
    Any help, gladly appreciated
    PHIL
    david
    by david » Mon Feb 20, 2012 10:08 pm
    You could trigger from button, but they should be configured as toggle if you want to toggle otherwise the "set" will be transient.
    What values are your buttons sending ? I should work as well with Note or ControlChange. But for example a Note will send a NoteOn on press interpreted as On, then a NoteOff that will be interpreted as an Off.
    With the Nano Kontrol (and any midi device), you can configure how buttons are working. So just configure your device to get the expected result.
    The "protocol" is the same as for DMX, properties are bool or float
    http://forum.garagecube.com/viewtopic.php?f=20&t=8029
    If you are talking about triggering media or preset directly, this is something we are thinking of.
    Regards
  • scaryxpuppy
    by scaryxpuppy » Mon Feb 20, 2012 10:17 pm
    Im using TOUCHOSC on my IPAD linked to OSCULATOR
    What I would like to do is have 10 buttons setup that can be configured to trigger PRESET 1 - 10
    As i say, it works great with a FADER asigned to a CC but this has values 1-127 so trying to get a precise number is quite difficult
    This would be ideal
    Many thanks again for your time on this - it really is appreciated
    PHIL
    by sigmasix » Tue Feb 21, 2012 12:52 am
    just in case, touch osc can output midi. Maybe you can achieve what you want without using osculator…
