Syphon button disabled. (Help needed pls)
  • yugakoc
    by yugakoc » Sun Feb 19, 2012 4:13 am
    Good day. Can some one please help me. When i go under output, the syphon button is disabled(grey). Can anyone please make any suggestions. I would like to experiment with the syphon and madmapper but i am needing the click syphon as the output.
    Something else i found that was strange. The tutorial i found on the madmapper says that the "syphon output size" under preferences would be set by default to 640x480. It keeps showing up as blank. I try change it and it just changes straight back to blank when i go back into preferences.
    Is there some kind of syphon plugin that i am meant to install or is it just meant to work?
    Any help will be greatly appreciated.
    Thanks
    DD
    Modul8 2.6.4
    OSX 10.6.8
    Re: Syphon button disabled. (Help needed pls)
    by sigmasix » Sun Feb 19, 2012 11:53 am
    Try to trash Modul8 preferences
    ~/Library/Preferences/com.garagecube.moful8_25.plist
    And you cannot output to a screen while outputting syphon so you'll have to exit fullscreen to enter syphon
  • CONTACT
    by CONTACT » Sun May 20, 2012 8:55 pm
    cvanhoose
    by cvanhoose » Mon May 21, 2012 12:27 am
    modul8_team: These are symptoms of cracked versions. Syphon will not work with your cracked version, I would suggest purchasing the software.
    You are number 3 to be brave to join the forum and post on the developers site after you have stolen their software.
