Bézier
  • fabiocatapano
    Bézier
    by fabiocatapano » Mon Feb 20, 2012 8:24 pm
    I would a module or a function to create Bézier Curve.
    http://en.wikipedia.org/wiki/Bézier_curve
    It's a very simple but comfortable tool to map irregular shapes.
    Re: Bézier
    by ilan » Mon Feb 20, 2012 8:31 pm
    For this we have the bezier function in MadMapper.
  • fabiocatapano
    Re: Bézier
    by fabiocatapano » Mon Feb 20, 2012 8:39 pm
    But could be nice if Modul8 (maybe in Painter module) can draw Bèzier curve.
    Because often I draw mask with illustrator directly on surface. But could be better from Modul8. Very simple. No like Mad Mapper
  • fabiocatapano
    Re: Bézier
    by fabiocatapano » Mon Feb 20, 2012 8:48 pm
    For example in this project I created mask by illustrator and after I imported PNG in modul8.
    But I think is faster and precise if I can (1) draw the shapes in Modul8 (2) create an output screenshot. (3) Import in Photoshop and create a mask. (4) import PNG
    An example
    Re: Bézier
    by ilan » Sat Apr 21, 2012 4:33 pm
    Definitely something we have in MadMapper now and it makes complete sense to us not to try and inundate Modul8 with such a feature as it has to do with overall output, something that MadMapper does very efficiently.
  • FranzKarl
    Re: Bézier
    by FranzKarl » Thu Nov 24, 2016 1:33 pm
    Hi There, yes we can create surfaces with Bezier, this is really cool. But can we create masks surfaces with bezier ? So that the loop we send to madmapper is still regular, and not distorded by the curves ? l mean, so that we could masks surfaces with curves instead of lines and angles ?
