hi nadinekhoury,
1. you can download both and test them. They are full functional. but they have a watermark.
you can then check out both softwares.
2. modul8 is the vj software from garagecube and madmapper is a mapping tool from the same company.
you can map with modul8 only but madmapper makes it much more easy to do difficult mappings.
3. check out:
www.modul8.us
http://www.madmapper.com/blog/
there you can find the most important information.
4. keep in mind that this is a vj software: it´s made to perform.
5. deepvisual has some very good tutorials
http://www.youtube.com/watch?v=iDyxDRkj ... eiiSMxGkGu
6. on the garagecube website there is a basic tutorial to get started.
http://www.garagecube.com/modul8/index.php?c=tut
i hope this helps
pele2010
