Utiliser Modul8 en output Syphon + Fullscreen??
  • Keydam
    by Keydam » Wed Mar 14, 2012 3:20 am
    Est- il possible d'utiliser M8avec une sortie en Fullscreen et une autre dans Syphon?? Et si oui..he bien comment!
    Merci pour vos réponses
    Damien
    (pour info je cherche a sampler en direct ce qui passe dans modul8, pour le relancer en tant que fichier .mov dans le logiciel)
    pele2010
    Re: Utiliser Modul8 en output Syphon + Fullscreen??
    by pele2010 » Wed Mar 14, 2012 10:58 pm
    Hi ,
    as far as i understand this.
    you whant to route the signal via syphon and via fullscreen.
    I would say : No , it´s not possible....
    You use syphon because of mad mapper or other apps that use syphon ....
    In this case MD8 is a feeder for the other software.
    If you need more outputs i think you would use advanced output.
    But this output does not work with syphon.
    ______________________________________________
    So :
    Syphon dualhead2go or triplehead2go and Md8 is the way.
    But maybe i just wrong and you could explain a bit why you need Fullscreen and syphon ?
    Because Syphon and the app you route the signal is then "fullscreen" , or not ?
    i don´t know .... just guessing ....
    i hope this helps you... and sorry for the english in the French form....
    (i´m german.... ;-))
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
