out of sync when fading to zero
  • Donleavy
    by Donleavy » Sat Mar 17, 2012 3:57 am
    Hello all
    I have 3 almost identical clips - with some variation in each clip but the same camera movement, so to speak.
    The clips are on separate layers. The layers should always be in sync so that I can fade them in and out on top of each other.
    My problem is this: When I fade a layer to 0% the clip stops playing. So, when I fade it in again it is our of sync.
    I did try the sync module, but it only works for layers that are above 0%.
    Any thoughts? I could really need some help!
    Thanks,
    Donleavy
  • Donleavy
    Re: out of sync when fading to zero
    by Donleavy » Sat Mar 17, 2012 1:57 pm
    ...for now (I'm in a hurry) I have resolved it by making faders that only go to 0.01...
    by vanakaru » Sat Mar 17, 2012 6:22 pm
    That is the only thing I could think of too.
