Modul8 - Lemur Template *update
  • lamepantallas
    by lamepantallas » Mon Mar 19, 2012 6:18 pm
    I have updated my M8 template for Lemur iPad.
    In my setup I use the following modules which have been included in the template:
    LT´s QuickFX
    LT´sLive Preview 4.7
    Preview Window Mapper
    BPM Global
    BPM Master Router
    http://liine.net/en/community/user-library/view/162/
    Cheers from Honduras!
    gabbo
  • Quickshift
    Re: Modul8 - Lemur Template *update
    by Quickshift » Wed Mar 21, 2012 6:36 am
    This was a big help in getting my first template together, used a lot of your design and modified it to suit my needs :)
    Question though, have u been able to get realtime feedback from modul8 to the iPad? i get feedback when it's requested, but i don't have buttons changing colors by themselves by anymeans with the 2Way Midi plugin.
  • lamepantallas
    by lamepantallas » Wed Mar 21, 2012 5:37 pm
    Great! Share it when you have finished your template:)
    Regarding feedback, I haven't been able yet, have not explored thoroughly
    Cheers!
    g.
  • zeburock
    by zeburock » Wed Jun 19, 2013 6:14 am
    I just found your template here for the lemur and modul8, was wondering if you have the midi mapping (exported from modul8)? Is that available for download too??
    That'd be great - better than having to guess and map it.
    Thanks! -Zeb
    broken
    by broken » Wed Jun 19, 2013 2:49 pm
    zeburock wrote:Hi,
    Thanks! -Zeb
    Pretty sure the mapping is done via OSC messages (built into the lemur template)
    Should be able to just run the OSC module in modul8 (don't run the lemur daemon) and set the IP addresses and ports.
  • zeburock
    by zeburock » Mon Jun 24, 2013 10:58 pm
    broken wrote:
    zeburock wrote:Hi,
    Thanks! -Zeb
    Hey thanks for your reply - I finally got a chance to try this out. I could see midi coming in from the Lemur app using midi monitor, via OSC - but Modul8 wasn't responding with any parameter changes... yes I did have the OSC module open and running
    Are you sure that is how it works? Can you try it, and if working post details about the setup, please?
    Thanks again for your help so far, =Z
    broken
    by broken » Tue Jun 25, 2013 3:54 pm
    zeburock wrote:
    broken wrote:
    zeburock wrote:Hi,
    Thanks! -Zeb
    My apologies.. I took a guess based on the steps I took with another lemur template and assumed this one would be the same.
    I tried this one out and while modul8 receives the messages in the OSC log and transmits, the template does not control nor receive the modul8 interface with just the OSC module.
    Perhaps Osculator is used in this instance to translate the messages rather than directly interfacing with modul8? Anyone know?
    I personally use a modified version of this template - http://liine.net/en/community/user-library/view/301/ (had to remove the position controls as my syphon output is larger than it allows and it snaps back to the x/y of the ipad)
    and can confirm it works great with just the OSC module.
    Hope that helps, and sorry for the confusion!
  • zeburock
    by zeburock » Thu Jun 27, 2013 9:54 pm
    broken wrote:I personally use a modified version of this template - http://liine.net/en/community/user-library/view/301/ (had to remove the position controls as my syphon output is larger than it allows and it snaps back to the x/y of the ipad)
    Hey thanks for confirming, too bad it doesn't seem to be ready and rigged... and thanks too for the great template reference. That does certainly look like a decent build, I'll give it a shot!
    =Z
  • fiumichino
    by fiumichino » Thu Jun 19, 2014 3:40 pm
    I confirm I have tried both versions of POPVJ-2.jzml and no one works on M8 v2.8, but they send/receive from the script output.
    I´m using Wavilox.jzml and everything is ok.
    Have you checked out your template?
