MadLab applications are do not work
  • vvvving
    by vvvving » Wed Mar 21, 2012 11:21 am
    I bought serial MM yesterday,
    and I was setup to my MAC book pro. ver1.1
    but when i open MadLab applications, it doesn't work.
    just blink on the dock, and soon disappear.
    so, i tried setup 1.2RC. but it doesn't work yet...
    plz help me.
    ps.
    my friends bought MM to, but his MM can work MadLab applications...
    my mac book pro is 13inch, uses lion 10.7.3 and it has SSD by ocz SATA3 vertex IOPS, and 8GB ram.
    Re: MadLab applications are do not work
    by franz » Wed Mar 21, 2012 2:12 pm
    some users have been reporting problems on Lion.
    does it crash ? which MAD_Lab app in particular ?
    some others have reported that some apps wouldn't work using the intel GPU
    (either GMA or HD3000).
    If you have 2 gfx card, try switching to the discreet GPU, by going into /System Prefs/Energy Saver/
    and turn off automatic graphics switching.
  • vvvving
    by vvvving » Wed Mar 21, 2012 4:05 pm
    Thx for your advice Franz.
    in my case, every Mad_apps do not working.
    it doesn't crash. just nothing to happen.
    but if i use only MM, it working really good.
    my friend also use MM in Lion. but his mac can work Mad_app...
    and my mac and friend's mac, both of them has intel HD3000.
    mac book cannot change its own graphic card...
    what can i do for work Mad_apps on my mac...
    by franz » Wed Mar 21, 2012 7:08 pm
    launch the console before launching Mad_Lab apps, and copy paste the console output
    to the support.
  • vvvving
    by vvvving » Wed Mar 21, 2012 7:36 pm
    system log.
    Mar 22 02:33:39: --- last message repeated 2603 times ---
    Mar 22 02:33:39 mac com.peter.ssdfix[87]: .
    Mar 22 02:33:39: --- last message repeated 33 times ---
    Mar 22 02:33:39 mac com.apple.launchd.peruser.501[197] ([0x0-0x92092].com.GarageCube.G3Player[943]): posix_spawn("/Applications/madmapper/MAD_Line.app/Contents/MacOS/G3Player", ...): Permission denied
    Mar 22 02:33:39 mac com.apple.launchd.peruser.501[197] ([0x0-0x92092].com.GarageCube.G3Player[943]): Exited with code: 1
    Mar 22 02:33:39 mac Dock[211]: no information back from LS about running process
    here!!
    by franz » Wed Mar 21, 2012 8:56 pm
    please contact the support by email
Users browsing this forum: No registered users and 46 guests
