MadMapper won't load anymore :(
  • TDXAV+
    by TDXAV+ » Mon Apr 02, 2012 2:38 am
    Hi all. MadMapper has been running fine for months. Today, the splash screen comes up, the MadMapper window comes up for less than a second, and then the whole program closes down. I haven't updated, changed anything, or installed anything new in weeks - nothing has changed. Any idea what's up?
    I've tried running without projector attached, without any peripherals or external storage, and I've restarted 3 times.
    MadMapper 1.0.2 on OSX 10.6.8, running on 2009 MacBook.
    Thanks for your help.
    EDIT: The CrashLog I accessed through the console just says "No Ports available for MIDI!" over and over
  • scaryxpuppy
    Re: MadMapper won't load anymore :(
    by scaryxpuppy » Mon Apr 02, 2012 8:43 am
    Hi there
    I have had something similar before where it seems to "minimise" as soon as you open it
    To resolve this I have clicked on the ICON in the dock and this at least brings up the MENU BAR at the top of the screen.
    I then go VIEW DESKTOP and this comes up
    If I now close the desktop window and click on the ICON in the dock again, it opens up as normal
    I hope this helps your issue
    Phil
