PNG VS PHOTO JPEG ?
  • Bucharest
    PNG VS PHOTO JPEG ?
    by Bucharest » Fri Apr 06, 2012 1:22 pm
    Hi ,just a simple question PNG KEEPS THE ALFA CHANNEL BUT PHOTO JPEG it doesn't keep anything .I am using Square 5 to convert from PNG to Photo Jpeg and the result it is not helping me.... the file size it is smaller but when I use the luma key in Modul 8 it is not working at all ,not clean no alfa channel ,pure and simple a washed out graphic element .....any suggestions ? Thank you
    Re: PNG VS PHOTO JPEG ?
    by vanakaru » Fri Apr 06, 2012 3:57 pm
    What is your question?!
    My suggestion is to take time to explain what you try to do and what you have done so far in detail. Please use proper sentences and plenty of words. It puzzles me why you want to convert PNGs? PNG+ is the only meaningful codec so far that supports alpha with Modul8.
