wierd bug...
  • tomtooms
    wierd bug...
    by tomtooms » Tue Apr 10, 2012 8:40 am
    hi
    i'm using modul8 for few month, and this is my first post on this very usefull forum
    however, i didn't find any solution to my problem this time...
    i got some bug suddently appears, and don't know what to do...
    description : when i change layerset (to usualy swap from A to B, to another A... etc) so i clik on the tab A2, and every B layers are suddently turned on !
    wosrt when i click on a B tabs, every A layers are turned off !!
    amazing isn't it ?!
    i first supposed it come from bad midi map ( using the two way midi modul ) but no, it still happennig even on a new blank project...
    i running 2.6.4, and madmapper,
    what to do ?
    thanks for help
    Re: wierd bug...
    by sigmasix » Tue Apr 10, 2012 1:41 pm
    what other modules are running?
    it looks like a module problem
  • tomtooms
    Re: wierd bug...
    by tomtooms » Tue Apr 10, 2012 11:40 pm
    hi sigmasix,
    yes it is actually ! thanks
    problem was comming from the (at) layer sequencer 10x16 v 2.3
    so i swap to the v2, and problem doesn't happend anymore !
    cool for good advice,
    and good to know that this modul is not working well... as several others apparently, but there's so much !
    thanks
