Is there a syphon for Corel Painter?
  • sageca
    by sageca » Mon Apr 16, 2012 5:06 am
    I am looking to do live performance painting using Corel painter, and I would love to be able to project via madmapper, but need some syphon support. Is there a existing syphon that will allow me to do that? Or are there steps that I can take to create one? thanks-
    s
    Re: Is there a syphon for Corel Painter?
    by ilan » Mon Apr 16, 2012 8:56 pm
    Corel would have to implement the Syphon framework into Corel Paint.
  • sageca
    by sageca » Tue Apr 17, 2012 2:04 am
    Quote (by ilan » Mon Apr 16, 2012 11:56 am
    ilan katin)
    thanks for the reply, and information.
    Another way to get the result I am looking for would be if there is a existing syphon enabled app, or plug-in, that captures your screen, or a portion of your screen. Any Idea if any thing like that exists?
    by ilan » Tue Apr 17, 2012 11:43 am
    I thought of this as well. Initially _vade (co-developer of the Syphon framework) tried to contact the makers of Pixelmator because it uses CI plug-ins natively. Unfortunately he received no response.
    A Syphon screen cap app might be possible. I have to ask _vade and some other folks who know more. I can't guarantee that there will be a solution immediately, but who knows.
  • sageca
    by sageca » Wed Apr 18, 2012 7:02 pm
    Awesome thanks for looking into this and helping brainstorm a work around!
    Loving the abilities of Mad, so amazed and impressed with the workflow, and versatility. Of course something this good makes you want to push it further!
    thanks-
    s
    by ilan » Tue Apr 24, 2012 1:55 pm
    Looks like a solution is on the way: https://twitter.com/#!/luiscript/status ... 7943549953
  • sageca
    by sageca » Sat May 05, 2012 12:12 am
    awesome thanks for the heads up!! If you see it become finalized please post the link here! thanks again.
